So this spring I pulled my boat out of storage and put it in the water with new gas and spark plugs. It seemed to run okay the first couple times in the water but then started to get very inconsistent. It had trouble idling and would stall when I tried to put it in drive. Now it won’t even fire. My linkages are all aligned, carbs are spotless, clean fuel filter, new spark plugs (that are sparking), new battery, new gas as well as new gas line from tank to motor. I am running out of ideas as to why it won’t start and am wondering if anyone out there has any suggestions or comments?
Sorry the motor is actually a 1989 serial number CJ70TLCEM
