Welcome Guest - Sign Up today
No announcement yet.
Fd-11 pressure tank
  • Fd-11 pressure tank
    Hey guys, I’ve posted here before about this motor. Hope you’re not tired of me yet? I set the points on this motor. I’ve replaced everything. Got great spark I’ve rebuilt carb. Only thing I haven’t done is rebuild pressure tank. It will pump up and send gas to the carb, but not sure about the air? How would I check to see if tank is holding pressure? Can’t get motor to start with tank. Could it be reeds or ? I’m stuck? Thx
    When you operate the primer you fill the carburetor with fuel.------When motor runs it starts pumping air into the tank.----Pressure in the tank then keep fuel flowing to the motor.
    • #3
      You aren't pumping up the Tank when you are pushing the Button/Plunger, you are actually operating a small Fuel Pump. If the Engine won't start after you have primed it, you can't blame the Tank. The best way to see if the tank is holding pressure is to, after the Engine has run for a bit, open the Fill Cap on the Tank. if there is pressure, you will hear it releasing, the fuller the tank, the quicker the Pressure builds up
      Great Spark? Can it jump a 5/16" gap? Wires going to correct Plugs?
      Rebuilt the carbs.... Did you remove all the Cor Plug on the Carb and clean out those passages? Is the Float New, and did you set it correctly? Idle Needle out 1 1/2 turns? Hi Speed Needle out one turn?
      What are the results of a Compression Test?
      • #4
        Racerone. Yes spark jumps 5/16, new coils, points, condensers, wires. New Carb kit, removed core plugs, new float,
        float is level. Passes the blow test. Needles set. Compression is 90 each cylinder. New head gasket. It’s a 6 gallon tank. Only put a gallon in? Got motor to start just for a second the other day by spraying gas into carb from spray bottle. If the motor won’t run how can I check that fuel pump that’s in tank? Thought about a new rebuild kit, but it is pumping gas? Can I pump that tank too much? Will it keep pushing gas into carb and flood carb? Thx
        • #5
          Any chance the air / fuel hoses were switched.-----Remove the high speed needle from the carburetor bowl.----Operate the primer on the tank.----Fuel should pour out.
          • #6
            Not if the float and float valve are operating correctly. Make sure the float isn't upside down, if possible on the FD-11 (think it is). I would set the top needle more lean, which is counter intuitive -- same with h.s. needle. Try with choke off. Fuel/oil mix 24:1 ratio.
            [referencing post 4]
            • #7
              No sir I marked the new hoses and traced them from tank to motor. I’ll check high speed needle this weekend . Thx for your help.
              • #8
                Oldboat1 I have double and triple checked this float. It’s usually not this difficult. I’ve set the points at the highest point on the cam lobe. Basically at the flywheel key. Everything in carb is new. Hell everything is new. Like I said I’m stuck.. thx
                • #9
                  Got a glass filter bowl, doesn't it? Check to be sure the gasket is fresh, and that the sintered filter is clear (maybe try it without the filter). The bowl will not be constantly full of gas.
                  • #10
                    Yes glass filter bowl on side of motor.
                    • #11
                      Sry racerone one I referred to you on a post, but it should have referred to jimmbo.
                      • #12
                        Glass filter can be a source for air leaks if the gasket is failing -- interrupts fuel feed.
