Welcome Guest - Sign Up today
No announcement yet.
83 15hp Evenrude takes to many pulls to start
  • 83 15hp Evenrude takes to many pulls to start
    I have a 1983 15hp Evinrude e15rcta. Very well maintained, sat for a number of years with the previous owner as a back up, which hardly got used. 100 on both cylinders, has good spark and we rebuilt the carb. We also installed new fuel lines, fuel connector, thermostat with seal and cover gasket. We gave under the flywheel a good inspection and when I get her to the lake, 32 pulls to start. One pull all day long after it warms up. All three times I’ve gone out after getting the motor, the same.
    Remove cover for the intake silencer box.---just 4 screws.------Pull choke on.-----Inspect ( mirror if required ) and look into carburetor.----Is choke fully closed , yes or no ?----And are you turning throttle grip FULLY against the neutral stop , yes or no ?
    • #3
      Okay racerone, just checked, choke fully closes. Yes, I do turn throttle grip fully against neutral stop.
      • #4
        What ro you call -----" good spark " ----on this motor ?----On the many motors that I have , good spark jumps a gap of 7/16" on a proper test device.
        • #5
          Okay, that will have to wait. I'm disabled and the person helping with the motor has the spark tester. Seems like a god time to go get a good one for myself. I'll get back with the answer. Thanks.
          • #6
            In this case do this test with plugs in and you pulling it over.----Sorry , there may be an issue with how fast you are able to turn the flywheel.----I am not there to see.
            • #7
              I have a couple of those, and find that the idle mix needle needs to be set a bit richer for cold starting (counterclockwise). Set it back to its leaner position when the motor is warmed up enough to keep running. Difference is about 1/8 turn or a little more.
              • #8
                when you serviced the " number of years" sleeping carb did you go.. all the way ?
                the idle mix screw allows gas to enter the small " drip" chamber on top of the carb .
                gas is sucked in via 3 very small drip holes and the only way to really be certain they are spotless is to open up the cover and clean them out.
                reseal the chamber with a new plug blow dry all orifices
                • #9
                  ^^+1. I disassemble and soak, then run soft wire into all openings (torch tip cleaners, if you have them) -- like to resist blow drying, though, as that can blast small parts all over the bench and floor.
                  • #10
                    If it starts warm it should start cold if the choke works. The only time this ever happened to me was when the gas tank was bad and on a cold startup the carb was dry.
                    Retract the ball on the motor fuel line connector and then pump the priming bulb to be sure it squirts gas really good. Then reconnect it and pump till you can't squeeze it any more.
                    2019 SeaRay SPX 190 OB & Mercury 150 4-Stroke & Merc 5.0 Kicker
                    2017 Boston Whaler 150 Montauk & Mercury 60 ELPT Command Thrust & Merc 3.5 Kicker
                    2015 Yamaha FX Cruiser HO
                    1964 Sea Nymph 14R & 1970 Evinrude Sportwin 9.5
                    1960 Mulray 100 Dinghy, equipped with Beaver Oars
                    1952 Lyman 15' Mid Steer & Evinrude Big Twin 25
                    69 Outboards: 1919-2019, representing 11 manufacturers
                    Member ACBS, LBOA, AOMCI
                    • #11
                      make certain ALL passages and air ways are clear …. including tank vent
                      • #12
                        If it takes 30 pulls to start one of those there is something wrong with the motor or the starting procedure.----Simple trouble shooting is required.
                        • #13
                          Wow, I went away for some time and you guys kept trouble shooting. I'm stuck at home "physical problems" so no spark tester yet.
                          To answer a couple of questions asked in my absence: Yes, carb rebuild went all the way. the person responsible is certified OMC mechanic.
                          When he test his work with muffs before he left, it took 3 pulls. It was with a different tank and line set up also. When running, it's a jewel. really smooth and responsive
                          I've been thinking along the lines of the gas tank as mentioned and Racerones simple trouble shooting at start up. I'm doing something wrong. Thanks for everyone's response. I jumped the gun asking for help when I won't have the boat out soon. Motor will sit awhile longer also.
                          • #14
                            oldboat1, I'm still a newbie and I have trouble wrapping the idle mix around in my head. When I'm in the boat, I loose all concept of lean and rich. I get nervous and draw blanks. Thanks for your input.
                            • #15
                              Jims123, I'm feeling it's down that road somewhere, thanks
