I have a 1999 Ficht 175hp that cranks up and runs perfectly. I can run it as far as I want with no issues. The problem arises when I stop for 10 or more minutes to fish, when I try to start the engine afterward it acts as if it is flooded and doesn't want to start. If I turn the key in short bursts, it will usually start sometime around the 10th attempt. After running if I shut it off it will crank right back up, the issue only exists after running and then sitting for 10 or more minutes. Any ideas?
