Carmageddon
- Jul 29, 2019
- 82
Hello!
I have the Johnson J50BECIC engine.
Since I bought the boat, I am having issues starting (may have started having those since I didn't initially follow the correct startup instructions I was given, but anyhow..) up the engine, and when it works, at WOT, after a while it just lost power for like 30 secs, and then shut down without me being able to start it back up (had to paddle!).
Other times when it starts, when I'd take slowly the choke down, it would stall and shut down about 1/3 way to close position.
I did some diagnostics, with a lot of help and advice on Reddit, I bought spark plug tester, and when trying to start, can see the light flashing in both cylinders, new spark plugs as well (NGK), so I think we can rule out the ignition system.
I had old fuel, I got it out and replaced with Super gas instead of regular.
I opened the carburetor air intake case, and sprayed in carburetor cleaner in while running on land (with water intake connected to cool the engine) - it was running fine for maybe 20 mins.
So next day, I took it to the lake, and surprise - it didn't start again!
Some Nice Guys who have much more experience and knowledge than me, tried to help me out, we tried to start it with different checks, but they noticed that there is way too MUCH gas in the water, speculating the ignition chamber is flooded with gas and sparks are unable to ignite it - I didn't have the wrench with me on the water.
But as per their suggestion, when I got back home, I tried starting again - having the same issue of not starting;
I then removed the spark plugs (didn't see much liquid, maybe it evaporates quickly, dont know) - I used compressed air from my compressor, to clean and dry the plugs thoroughly, as well as the ignition chamber though the spark holes.
I reassembled it all, and it started immediately!
After a minute or two idling, I turned it off, and tried starting again - this time again, it stalled when I got choke to 1/3 or so.
So, based on all that I've been told, it seems I have two issues:
Thanks guys!
- Carburetor sends too much fuel into the engine - can I adjust this without taking the carburetor apart? If not, How to clean it? I have a kit coming in a few days, but the videos I have seen online are not detailed and specific for this engine.. I still don't feel confident doing this.
- There may be some grain of dirt or something in the bowl, and when in WOT, that something intermittently gets stuck in the jets or something, and that causes the 30 secs lower power output at WOT, when it finally dies.
This theory made sense, until the above theory was kind of confirmed with me venting the spark plugs with air... on the other hand, this one may still be the reason for the WOT issue so need to clean the carburetor anyway?
Thanks guys!
