JJB
- Dec 28, 2006
- 274
I wanted to get some advice. I have a 2000 Johnson brought it used and have put about 700 hrs of offshore run / trolling over 10 yrs. I have 100 psi across all cyl. she starts right up runs good but smokes like a fish smoker lately. I do hear a slight knock off and on in the lower end of one cyl.at time. it just started the knock last time I was out . could the lower bearings be past clearance and sucking fuel/oil past it? can you have ok compression and get some blow by into cylinder? I have always pre-mixed my gas/ oil 50:1 using premium oil in it. thanks for the input!
