wfburton159
- Jun 20, 2016
- 20
I have been having all kinds of trouble with my 1995 Johnson 60HP 3 cylinder fouling plugs. It will drop to two cylinders fairly often but then come back to 3 cylinders. Seems completely random on when it does it. This past weekend I pulled off the thermostat cover and found small chunks of rubber on both sides of the thermostat. The rubber chunks looked like pieces of an o-ring. Any ideas on where the rubber is coming from? Water pumps almost instantly out of the side discharge. Once up and running on all three cylinders the plugs look nice and tan after a two mile full throttle run. So I am wondering if that rubber has been hanging the thermostat up? This has been going on for three years though so not sure of that. This weekend I will check the primer (electronic primer by key switch) for leak by when off. Its really rich on idle and mid throttle. Full throttle it will clean up. But I have the idle fuel screws set at 1 to 1 1/2 turns leaner than suggested initial setting.
