Good Trout To You Sir
- May 22, 2018
- 85
Pull cord condition, recoil function, idler (start) gear condition all seem good. But arm idler gear (part #43) -- the outer cup housing -- wobbles more than I would expect. The "sandwich" of the assembly is not tight enough for pieces to meet for starting, so I must apply pressure on the outer cup housing (part #43) to cause the starter gear to pop up into position to meet the flywheel.
Starter bushing and shoulder screw appear positioned properly. I have torqued shoulder screw to 12 foot-lbs.
How to diagnose issue without creating a spring-winding exercise unnecessarily?
