Evinrude 1997 25 hp shift rod question after water pump kit
Jim Towers
Engine is a Evinrude 25 tiller, 1997 E25RLEUM Serial G 04220468. I have followed advise to get shop OEM manual and have replaced the water pump with the kit. While doing this I turned the shift rod while dis-assembling the coupling. I have reassembled it but do I need to readjust the length? does turning the rod shaft screw it in/out the lower unit? The manual shows adjustment at the top of the engine in the linkage. I have not started it yet due to the weather in NY.
Jim Towers
Update............I found an earlier thread that describes how to check and make sure you have the bottom shaft screwed down in order to shift correctly, finally turned up in a search that used those key words...... thanks to this site and all that contribute!
