OK, picked up this evinrude for $300 bucks. Pretty fair shape. Did all the routine maintenance, carbs, water pump, thermostat, plugs. Shes got 120 lbs compression on each cylinder, very nice there. Did the heads and exhaust housing, cleaned those out....etc, etc.
No spark now. Actually, intermittent spark on #1 only, tested at 7/16". Nothing on the others, and #1 is very intermittent. I did pull the plugs and touch to block, and they all do sp New battery, good cranking speed, NO voltage leaking in black/yellow wire. Stator is not melted, timing base turns freely. Wet plugs. Key turned on, no lanyard-kill on this model.
I did purchase a new CDI power pack, and here are some measurements I've taken per the CDI guidelines and the OMC service manual:
Brown to Brown/yellow: 200 volts (with DVA). Ohms around 580.
Black/white #1 to black/white #3: Ohms 6.8, DVA voltage .80
Black white #2 to black/white #4: same as above. Ohms shows low per CDI instructions
Black/white all to ground: 0 volts, ~200 ohms resistance when meter set on 200K (manual said set to HI ohms..?)
White/black all to ground: 0 volts, ~200 ohms resistance when meter on 200K.
Removed the yellow rectifier wires, no change. Ignition coils look good, no cracks, some rust on the metal surrounds. I've cleaned every ground I can find.
Flywheel looks good except for 3-4 chips in the trigger magnet. Its not loose.
I'm at a loss, I think its a timer base issue, but I'm not sure about the flywheel either. I have the tools/meters to check all this stuff, just can't quite follow what it all means.
Any help appreciated.
