The motor now is a 1995 115HP Johnson offshore. The motor was on an older Bayliner but was clearly replacing a different motor so it’s hard to say what the controls may have originally been for. The throttle cables are Johnson but I’m not certain the gear controls are ?? If that’s possible ? The M on the bracket has me curious if it’s posdibly merc cruiser controls ??? I have another side mount box but it doesn’t have the tilt and trim so I was trying to make this work. If I can’t fibd that piece I likely remove the tilt trim cable and use my Johnson control box for exclusively controls since my ignition etc. is already mounted to the center counsel I’d just have to figure out the neutral safety switch.. it’s been a beast of a project...
