have 1984 evinrude 90hp that barely turns over when i try to start. hook up battery cables, neg. to engine block and positive to solenoid. again motor barely turned over. cleaned all cable ends including lock washer and nuts. same results. question how do i check solenoid? don't want to start buying solenoid or starter unless i need them. hopefully somebody can steer me in the right direction. i don't own a volt meter.
thank-you very much,
john
john
