There is a small hole next to one of the lower gear case bolts aft of the propeller. If you're looking at the propeller, it's top starboard side. Never knew they had one. I was testing the motor in a tank, I walked away for a few minutes and had oil water when I returned. Any suggestions on what I'm looking at for a repair? Looking at the exploded view in a service manual. I come up with 2 seals plus a water tube grommet. I'm I close? I'm completely new at this but very determined to avoid repair shop. Thanks for any time and consideration on this issue.
