iisindpink
- Nov 25, 2018
- 2
my Johnson wont make full throttle it just stops revving at near full throttle doesn't cut out but I have to throttle back then up again to get it back to upper revs. I have read a very good post on this site I think it was posted by seahorse,in which he states that you should not use cable ties on the fuel line or jubilee clips as they can cause air leaks, my engine has cable ties on all the joints I lost count at 15 so it would be quite a task to renew them all ,does anyone know if this could be the cause of my problem,when its running as high as it will rev and I push the key in (excess fuel)it will rev higher for just a second or so before choking. any help gratefully accepted,thanks. iisindpink
