wannabewelder
- Aug 10, 2018
- 71
Hi all, have a 85hp evinrude with VRO crank won't turn. I pulled heads and #2 and #4 seem to move 1/8" back and fourth but 1&3 won't. Bores are clean, cross hatch good, the pistons wiggle side to side. Was wondering about possible wrist pin jammed in ports or piston ring cracked. Ultimately needs a tear down and check rod sizing in case the previous owner had a pipe on the crankshaft. No rust. Just wondering what I may be getting into?
I was going to drop the foot and check pump (will do impeller anyway) but #3 seems to be the issue. Anybody been there yet? Thanks.
