Need some advice and expertise on figuring out what’s up with my evinrude outboard. Been running great until it sat for a while and used ethanol gas couple times. At high rpm 4500-5500 rpm runs for a bit then starts to bog down from 5k to 4K up down up down. Gets up on plane great then once up and throttle down to 5k the issue arises. There’s like a sweet spot at 4500 where it will run fine, anything higher rpm it will start to bog up and down.
The vro pump is bypassed and am mixing fuel/oil. Newer water fuel serpeator installed recently also. Running on 12 gallon auxilrty gas tank not factory boat tank.
Things I have done since,
removed carbs/ soaked and cleaned out all crevices.
good compression when engine hot
replaced voltage regulator
all new coils, plugs, wires,powerpack.
Do I need to sink carbs?
Clean/rebuild gas pump diaphragm?
thanks
thanks
