1969 25 hp Evinrude Oiler line hookups
BlackoutBill21
finishing up putting together my 25 hp and don’t remember where the smaller rubber what I believed to be oil lines?
I have 4 nipples to connect to. One comes from the intake manifold, the other is at the top of the crank case.
one is the forth bold for the exhaust cover plates (the same opposite /lower of the plates that holds the fuel pump
and the last is on the bottom of the crank case near the last mention one. In between that one and the one on the intake manifold.
thanks in advance
F_R
Crankcase drain hose between intake manifold and bypass port cover plate. (Might be a special hose larger on one end than the other end).
Oil hose between bottom and top of the crankcase, takes oil from the bottom to the top bearing.
