andrew j cox
- Feb 11, 2015
- 149
Hi guys,
i was given an old johnson 20 hp 68 vintage, hoping i can find someone in oz that might have a wreck or know of one, its missing the mixture knob and bellcrank, on the cover where the pull cord comes through is a metal plate this has worn right through to the top fibreglass , the big rubber grommet that the cord comes through on the inside is not there,
the throttle shaft the inside one that goes through the lower cowl is flopping around, was toldtheres a little plastic thing that breaks, could be the bush is buggered too
the gear shift is very stiff will get fwd n nuetral but no reverse,
the stop button is also broke, can a conventional auto start button be used?
the engine has never been salt water id like to get it going and use as an auxilliary on my big boat, appreciate any leads or ideas on the probs, cheers.
