1983 115 Johnson coil order?
111torrance111
Just bought a new set of coils for a 1983 115 HP Johnson. it comes wired together for the port side. How do I know which one goes where?
There's an "A" & a "B" side in the manual, but it doesn't show top or bottom. I like liked to know how to tell the A/B side for each side.
Thanks in advanced for your help.
I do have a manual, it just doesn't show this detail. I assume I have them backwards that will mess with the timing.
Jerry
111torrance111
Thank you oldboat1, I'll assume the coil numbers on the drawing is associated with the firing order. Correct?
Jerry
The A is for the top coil # 1----And A is for # 2 on the other side.
interalian
On the motor side of the plugs with orange wires - the orange with blue stripe is to the top coil.
111torrance111
The drawing that Oldboat1 supplied did the trick, got the coils in the right position and everything worked great. I found a similar drawing before but it didn't show the position numbers like the one oldboat1 supplied.
Thanks for the help.. already had a successful weekend on the water.
Jerry
