RoGun_Mako171
- Jun 25, 2018
- 79
I'm trying to figure out why my engine is running very rich at idle. I'm seeing a lot of oil in the water that is bubbling up from the exhaust when idling on the lake, a considerable amount of smoke, an oil slick around the engine at idle and black sort at the waterline on the stern of my boat at the end of the day. Following the service manual, I have gone through the carbs many times to clean them up and make sure I do not have plugged orifices, put in new floats, float valves and valve seats and adjusted the float setting with the Johnson float setting tool. Have done the tests on the primer solenoid and it checks out ok. Hoses appear to be routed correctly. Still, running very rich at idle.
Looking at the service manual Fuel System Trouble Check Chart for Engine Rich at Idle, I'm thinking it's either the float valve stuck open or the float valve is installed incorrectly. However, when I pump up the primer bulb it gets hard so I'm doubting the float valve being stuck open. What are other tests of the float valve being stuck open? And as for the float valve is installed incorrectly, maybe I'm missing something, but how is that possible when it's just a wire clip that hangs off the float arm? Any other ideas why this is happening? Compression is #1:125psi, #2:115psi, #3:125psi, #4:110psi and spark test looks good on all 4 cylinders. Am I just blowing oil/fuel past the piston ring on #4 and that is ultimately my problem?
