Hemi hammer down
- Aug 21, 2018
- 4
I need help! We were boating a week ago on our pontoon with a 2000 70hp Johnson. We left a fishing spot and started speeding up when the motor chugged hard twice then quit. I tried to start with no luck, I squeezed the primer and it fired but would barely run above idle then I got a no oil alarm. So it seems to me a fuel pump/vro issue. If it’s not pumping fuel then it’s not pumping oil correct? The local shop told me a straight pump is upwards of $350 and I have to mod the bracket and premix, the bracket and premix are no issue but $350 for a pump? I can get a new vro for $400 neither of which I can afford right now. What do you guys think?
