831Bass
- Jul 10, 2018
- 60
My fiancé and I just got a new to us boat with a Johnson gt 150 and we had a hard time getting it started but once we did it seemed to be running great and fast (loose plug wire). Then as we were bringing the boat up to speed one time engine cut out and the over heat alarm came on and the motor was smoking a bit. Looked at the the gauge and it was pegged. Let the motor cool for a bit and noticed a clump of weeds and moss caught around the intake area. restarted it and it idled ok so we put into gear pretty quick to try to get back to the dock but it died. We then ran out of battery trying to start it again (battery was already low)
I did a compression check today and 4 cylinders were around 80-90 and one 60 and one under 20. My question is where do I go from here? The plug from the lowest cylinder was pitted and I can see inside that the piston crown thing looks pitted also.
Will I do more damage if I try to run it and limp by while saving for rebuild? Any advice, opinion or input is appreciated
Thanks in advance ,
Brian
Thanks in advance ,
Brian
