xNecessityx
- May 31, 2018
- 11
Hello Everyone,
I have had this engine for years and didnt think much of the 4500 max rpm and 25 mph until recently when I saw that many people with the same boat (1997 HS 2450 walkaround) and engine as myself were getting around 5500 rpm and + 10 or more mph. The engine also runs a little rough and will shake but does not stall or die on me. At first I thought maybe it was the prop that needed to go lower in pitch, it is currently 15x17 but Ken over at Prop gods stated that it should be performing better and I may only be running on 5 cylinders. He mentioned that the coil packs and power packs are known to go bad on these engines so I did some research. I bought an inline spark tester and a multimeter to read the ohms on the spark plug wires. The spark tester was lighting up for each plug but I noticed that the spark plug wires were corroded and did not look great at all. I was also not able to get a reading on most of the spark plug wires. I apologize for the long post but any help would be greatly appreciated.
Thank you
Thank you
