I went out to day for the holiday to run the boat with the family and had problems with boat motor! The motor would not crank even though primed and chocked. The motor ran flawlessly last weekend. In the course of trying to get it to start, i burnt up a new stater. One thing I noticed today which might be normal? When trying to use fast idle (the style i have is the one where you push it in on the throttle and engage the throttle once the fast idle bottom is pushed). When doing this with the motor not running it want crank. Is this normal for the motor to not crank with this design fast idle until the motor is cranked? Also i cant believe i have burned up (2) starters when trying to crank the motor! Any help would be great! Oh how i dislike a 2 stroke cold natured motor,
