You start with posting more information and you may get to the bottom of the issue.----What are the compression numbers ?---Do you raise " throttle only " lever for starting ?---Do you push in the key while cranking it over , yes or no ?----How long have you owned it ?----When did it run / start properly for you ?
I got the boat and motor late last summer. It was not running. Compression is 120 on both cylinders, I checked the spark with a spark light and last fall I replaced all the fuel lines, changed out the VRO with a fuel pump, changed the inline fuel filter, and cleaned the carbs . It was running great and over the winter I put about 20 hours on the motor. I did have to adjust the idle mix screws once but I have been out multiple times without adjusting since. The last time I went out was weekend before last . She sat last weekend and this weekend she wouldn't stay running .
The choke is not working. This is my normal start routine. I flip the manual switch and crank till she fires, flip the switch down and give about 1\2-3\4 trottle and she fires up. I keep it throttled up for about 20-30 seconds then she idles great . Once she is warmed up, I don't have to use the choke . Last time I was out, I was trolling about 2-3 mph and turned her off and restarted multiple times. Had 0 problems.
This weekend, I added fuel (50:1 mix) drove to the lake, did my normal starting routine but after the crank with choke, it would fire off for about 3 seconds and die. I tried adjusting the idle mix screws but it did the same thing every time.
