Makersmarc
- Feb 12, 2018
- 2
I have a 9R-73B Johnson 9.5 that I bought to use on my personal boat I use exploring rivers and creeks looking for wildlife. Cosmetically it's in great shape. I've rebuilt the carb and put in new points/condensers. I ran it on the lake on my 12' aluminum boat and it had good power. The problem is that it's a bear to start. In the test barrel, I use a 1/2" drill and socket on the flywheel to start it. After about 15-20 seconds of cranking it will start and then run okay. Once it warms up it runs smooth. However, when I am out on the water (and have to use the rope) it is impossible to start.
The compressions are both 41# on a warmed-up engine. I have resigned myself to the fact that I will have to overhaul this engine. I have used the Sea Foam treatment to try to de-carbon the rings, no joy.
Before I start breaking it down I would like to know what I should anticipate as far as parts replacement. Besides the usual stuff (gaskets) what is the best practice for an overhaul? I am inclined to just put in new pistons and rings and reuse the wrist pins et cetera provided everything fits together within a reasonable tolerance.
Also, should I need to have the cylinders rebored is there a good source for 0.020 oversized pistons?
