Hello,
I've recently come into a 1975 Evinrude 115hp outboard. This motor had not been started since 1996. I got it started (cleaned carbs, new sparks) and it runs great now. I'm new to Evinrude's, but I'm conceded that it might not be cooling the heads. I know that this motor does not have a tell-tail, but it?s my understanding that water should come out of the two exhaust ports directly below the powerhead. Right now, a very fine mist comes out, nothing like what gets pumped out of my 1965 18hp Evinrude Fastwin. I have replaced the entire water pump and housing. And when I disconnect the water lines into the heads, water is now pumping (hard). I?m just unsure how much water should be coming out of the exhaust ports, if any at all. I might be over thinking this, but I just don?t want to get out on the river and seize the motor.
Thanks for the help.
