I have a 71 skitwin with a no fire on the bottom cyl. I'm sure I checked both and were good to begin with. Since then I had the starter rebuild and carb. Lost fire somehow on the bottom cyl. Could it be the wires on the cutoff switch or ignition switch. A few wires fell off the switch and since then have had trouble making sense of what previous owner done ..
For example I can get it to start but not shut off using the key switch. It was a hack job when I got it so at the point loosing patience. Points etc are all new...
What wires go to the vacuum cutoff switch...
