bamabutch90
- Sep 1, 2016
- 11
1997 Evinrude 115 (E115SXEUA) mounted on a 1992 Centrury 1800 Center Console, I ONLY run 100% fuel, Quick Silver 2 stroke oil (pre-mix), Quick Silver gear oil.
119-120 compression on the cylinders
My Problem:
3.5 years ago had the power head rebuilt. Since then I kept getting a temp alarm. i took it back a couple of times and they said the head was warped because I over heated it but they put another rebuilt head on (supposedly) Also had new water pump installed in it (now 2 years old). I could run the boat from idle to 3400 RPM all day long but once I went over 3500 RPM I would get a temp alarm within a few minutes of cruise speed. I replaced the water pump ..... it kept doing it. I took it to the shop, they said I installed impeller backwards, it kept doing it after they installed another impeller. So after much debating and lots of money down the drain, I took the thermostats out (yes I know it is designed to run at a certain temp, but we have no problem getting to that temp in South Alabama I promise) When i removed the thermostat housing the Starboard side Thermostat came out in pieces. So I thought problem solved. NOPE... now get a temp alarm within minutes after throttling towards cruising speeds. Motor has never faltered. So I thought maybe I just had a bad sensor in one of the heads so today I put the muffs on and let the motor idle to let it heat up some. Dug out my handy dandy IR Thermometer and tada the port side was about 30 degees hotter than the starboard (I didn't leave it cranked long enough to get an alarm) the Starboard side head temp (area right around spark plug) was 150-166 degrees F which is what I would expect with no thermostats) the Ports side was running between 192 and 211 degrees. My Question is where do I start. Do I take it to a DEALER (lots of money) and have them put in a new water pump the stream is decent but I have seen it stronger. Or do I check else where? I have read about some water connections that need to be checked if your motor ever overheats but think i read where they are behind the crossflow cover... Any how any help is appreciated.
Thank You
My Problem:
Thank You
