1967 40hp Johnson super seahorse question? Long to short shaft?
56Crestliner
Hello, I just picked up this Johnson today for my old boat. Based on my measurements it is a long shaft. What I am wondering is if I can remove the section that appears to be about a 5 inch extension housing and convert this to a short shaft? The seller threw in a parts motor, and I have a short shaft shift lever. Would I need a different driveshaft, or is there some sort of extension that makes this a long shaft?
Any help would be appreciated,
Thanks Jeremy
Remove those 2 covers.--Remove the rear exhaust cover.---Remove the lower unit.----Remove the 5 inch spacer.--Install a shorter driveshaft;----------Needs shorter water tubes.----Shorten shift rod 5 inches.--------But before you do all that you should evaluate the condition of the motor and perhaps run it.
F_R
Water tubes pull out. Cut exactly five inches off them and reinstall. Yep, you will have to replace the drive shaft. You will also need a 5 inch shorter rear bolt holding the gearcase on.
56Crestliner
Well that seems doable. I did run a compression test on it and we ran it in a barrel before I bought it. It seems like a strong motor. You're right, probably a good idea to throw it on the boat in the spring and run it a little before going to the trouble though.
So next question, the 40hp Evinrude Lark 2 that he gave me for parts is a short shaft. Would this driveshaft be compatible?
Thanks again for your help!
Likely the same and the parts you need for this simple conversion.
oldboat1
If both are mechanical, may be able to just switch out gear cases. When ready, would probably drop both l.u.'s and check compatibility. Driveshaft splines must be a match. If the switch works, save the Johnson longshaft lower unit for future use or to sell with the motor.
