Re: 2003 Tohatsu 9.8 2-stroke engine - decreasing performance, compression numbers
I will keep the 7 pitch prop for sure, with some more gear and a cooler the rpm will fall below the 6000. My concern was running the motor at and above the upper limit of the recommended band when the boat is lighter. I agree that an 8 prop will be my best bet though, in case I want to shoot for another one. Not sure 1 mph improvement is worth it...
