Welcome Guest - Sign Up today
No announcement yet.
Tohatsu 9.8hp 2stroke remote steering connections
This topic is closed.
  • Tohatsu 9.8hp 2stroke remote steering connections
    Hi
    I wish to fit remote steering to my Tohatsu 9.8hp 2stroke outboard.I have the remotes fitting kit which includes all the bits for the throttle and gearchange.All that is included for steering id the "Steering Hook Plate".
    The owners manual doesn't mention remote steering at all.
    How does the steering cable connect via this plate? Do I need a drag link bar?
    Does anyone have a pic of the steering setup for this engine please? Or explain how it all connects and what other bits I will need other than steering kit with a cable.
    Thanks
    Richard
    Re: Tohatsu 9.8hp 2stroke remote steering connections
    Yes, you do need a drag link bar. Shoot me an email address and I will send you a PDF parts manual for your engine that shows where they all go.
    Elvin
    My answers are like Zen...It may not be the answer you want, but it is generally the answer you need.
    The 3 Rules:
    1) Look in your service manual first...Then ask me if it is correct.
    2) Understand that your desire to repair your engine does not mean that you have the ability to do so.
    3) If you are confused, take your engine into a dealer..Then let them be confused...At least, in theory, they sent someone to outboard 101.
    • #3
      I think he has a 9.8B model. I don't think they offer a link arm for that model as there is no steering tube - right?
      With the hookplate you can still use a regular quick-connect steering system but you will need an additional piece from Teleflex (or similar) called a transom clamp block. Basically this piece installs to the transom and holds the exterior of the cable stationary so the end of the cable (connected to the hook plate) can travel in and out, turning the engine from side to side.
      You could also use a pulley system but those are a pain and harder to get parts for I think.
      • #4
        Depends on your steering system. The 9.8B does not have through tube steering, so Tohatsu does not have a factory steering link designed for that model. If you use the T & R front mount steering adapter kit you do need to use a steering link arm which is available from...T & R.
        Elvin
        The 3 Rules:
        • #5
          Thanks for all your advice
          Thankyou Elvin for the Parts Manual
          I understand what I'm doing now!
          Richard
          • #6
            Trying to do the same thing.. please let me know how you did it.. regards
            • #7
              Jesus jose
              dickandjill has not been here in over 8 years. Please Look at the Help Tip on top of the page and start a new topic. New topics are the best way to get advice. the old topics are usually ignored. Thanks.
              Closed.
              BOAT SPECS | FORUM HELP | STARCRAFT FORUM | SHOP iBoats
              Please, no PM's (Private Messages) regarding boat/engine problems.
              That is what the forums are for.
              Only forum/moderator issues will be answered in PM's.
