MarvinGabriel
- May 5, 2020
- 83
Ok, just finished installing the tiller, and have an odd issue. The engine doesn’t idle correctly, and stalls on occasion, even when warm. When it stalls, the only way to get it to start is to choke it, and turn it to wide open throttle...sort of like starting it flooded, but choked...weird, right? Once it starts, it sort of stumbles all through mid range, but runs great at WOT. The engine has 125 lbs of compression in both cylinders, I’ve cleaned the carb and fuel pump, and filter. I’ve also replaced all of the fuel hoses ( all just routine maintenance In my opinion. Oh, and I only run premium fuel with no ethanol in the boat. I use Quick Silver oil. Any ideas? It ran fine last time I used it, and only changed from remote control to tiller.
