Welcome Guest - Sign Up today
No announcement yet.
Plastic Cam puley remove in Tohatsu 8, 9.8 15 20 hp
  • Plastic Cam puley remove in Tohatsu 8, 9.8 15 20 hp
    Hi.
    is there any tool to remove cam puley from valve shaft. This cam puley is made in black plastic.
    i dont want to brake it or brak cast iron valve shaft.
    any tips?
    I have never needed one; it's not a press fit. I suppose you could use a 3-arm puller if needed.
    Paul
    Certified Tohatsu TLDI Technician
    Buffalo NY USA
    • #3
      well,it stack very hard. i put under the puley 2 flat screv drier and tap into shaft. the end of story was broken top of cam shaft
      on top of the puley are 2 holes. i think its for puler.
      the right puler is 3AC-99736-0 +3AC-99737-0
      • #4
        On an MFS8/9.8?
        If there are 2 threaded holes, yes, you can use a harmonic balancer puller.
        So now you need a new cam as well. Ugh.
        No mention of a puller in the Factory service manual for the MFS9.8A3...
        Paul
        Buffalo NY USA
