HotTommy
- Mar 15, 2013
- 1,025
I'm beginning work on the tilt / trim system on my 1993 Force 150 outboard, and I suspect I'll have more than the one question I'm asking now. So I'll be using this thread as I proceed.
My first question regard the wiring for the tilt/trim system. According to the FSM, power to the two relays that control the pump begins at the hot side of the starter relay and goes through a circuit breaker before before arriving at the relays. On my engine, the only thing between the starter relay and the tilt/trim relays is a section of slightly thicker than normal wiring. I suppose it is possible there is a compact circuit breaker in there. Should I be looking for a more obvious circuit breaker or was the factory circuit breaker small enough to pass as a wide spot in the wiring?
