New to me engine idles about 800 rpm pumping good water. If i throttle up it will start to pop like lean and sometimes stall. It will always start right back and idle well. When i got the engine idle Was set to about 950 rpm. Now with idle set to 800 rpm it makes some noise from neutral to fwd or rev. I'm thinking pop off idle may be head gasket?
