acdc96
- Apr 23, 2013
- 412
My 1991 Force 9.9HP outboard is due for a water pump impeller change out.
I have never changed it myself. I'm the second owner. Bought it from my cousin about 4 years ago. The thing is in pristine condition. clean and works perfectly. He told me that it was changed about 8 years ago. The marina changed it for him. My local marina said it would cost about $150 to replace the impeller. Not paying that for a $15 part. I've changed the impeller on my mercruiser alpha drive before and it was easy.
Is their any procedure I have to do to pull the lower unit off? And anything else I need to do while the unit is off? I already change the gear oil.
Also is their any anodes on this motor?
