I have a 1988 85 hp Force. The engine and tilt have worked flawlessly for 20 years. The boat has been sitting for the last two years with no attention given to it. I recently decided to see if I can take it out by the end of this year. During my initial checkup of the boat I found and did the following:
Thanks
- Trim motor did not work
- I replaced motor
- Connected lines - motor runs but no tilt or trim movement
- Removed lines from VB and operated tilt switch
- No fluid comes out of valve body
Thanks
