Welcome Guest - Sign Up today
No announcement yet.
1998 Force 120 Tach wiring
This topic is closed.
  • 1998 Force 120 Tach wiring
    Hi All,
    I have been frustrated with tracing the Tach wiring on my outboard. Does anyone have a diagram from the motor? My tach goes to 0 when the ingnition is on, but I see no AC voltage on the SEND of the Tach. There is a grey wiring coming out of the Voltage regulator and it goes into a potted housing on the back of the motor and on the bottom there are a few wires comming out. One is tan and not connected to anything. The others are for the trim. Is this tan wire the one that is supposed to run back to my trim gage? It has a crimp on it, but just hangs in space. There does not appear to be a wire to connect it to. Is the grey wire on the regulator the one for the tach or is it the yellows? Why are does the main wiring harness coming from the controls run into this potted housing and what are the color codes? any help is appreciated. Thanks
    ps my battery voltage goes to 14 when the motor is running so it is charging
    Re: 1998 Force 120 Tach wiring
    The grey wire is the tach signal wire on my '96 Force 75. Hope this helps.
    On a side note, I was able to use a teleflex tach wiring harness for a Mercury, plugged right into an unused connector on my factory harness at the helm.
    • #3
      I installed a tachometer on my boat and I don't know where is the sender cable , I have a 1996 mercury force 75 please help
      • #4
        There are only two wire colors used for the tach input for Force motors, i.e. gray or purple.
        • #5
          The grey lead is the tach lead.
          The purple is the power to the tach.
          If your installing a new tach, look in the wiring harness from the motor.
          They usually tape the extra leads back.
          The tan could be an extra lead in the harness for an alarm sender from an oil system the Forces don't have.
          Buy American made Cars and Trucks!!!Towing insurance for a boat,a GREAT thing.
          ​Tools to make my life easier: Battery tester, die grinder, temp.gun, compression tester, DVA meter.
          In Scenic , Beautiful San Sebastian by the sea Florida
          88 Bayliner 21CC 2001 Mercury 225 HP EFI
          PLEASE,NO PERSONAL MESSAGES IF THE QUESTION CAN BE ASKED ON THE OPEN FORUM I WON'T ANSWER AS MY SYSTEM CAN'T REPLY TO YOUR EMAILS
          • #6
            Ancient thread.
            Bob, Seneca Lake NY
            '88 Bayliner 1700 Capri bowrider, 85 HP Force O/B, "Sea Weasel"
            '94 Grumman Fish'N Fun pontoon, 40 HP Merc
            Want a vessel safety check? Click here. Want to join the Coast Guard Auxiliary? Click here.
            Disclaimer: Although I am a member of the USCG Auxiliary, the opinions and advice in my replies are my own and do not necessarily reflect CG or CG Auxiliary policy or regulations unless so specified.
            • #7
              Closed, it's just easier.
              BOAT SPECS | FORUM HELP | STARCRAFT FORUM | SHOP iBoats
              Please, no PM's (Private Messages) regarding boat/engine problems.
              That is what the forums are for.
              Only forum/moderator issues will be answered in PM's.
