DunbarLtd
- Nov 8, 2016
- 335
Force 88 85hp
I decided to replace the adapter plate paper gasket after failing to fix a leak with silicone.
All went well with lifting the motor and lowering. Got everything back together fine.
The only thing I noticed was where the water tube comes up into the power head. At the surface of the adapter plate there is a bracket that holds the water tube in place with two bolts. The inside of the bracket is hollowed out to accept the copper tubing.
I cant find this bracket in any parts listing.
And the reason for this post is that I am not sure if there is a rubber bushing that goes inside the bracket thatll hold the water tube in place , which has a slight flange on it??
Is there a replacement bushing for this or is there just silicone?? I just built up an rtv ring around the outside of the pipe but im afraid i might have used too much and when it smushed down - the water tube may be blocked off and not get water to the power head.
Anyone have any idea on this? Thanks and HAPPY THANKSGIVING!
