Most likely, the tower shaft is stuck somewhere. Disconnect the control cable from the tower linkage and you should be able to move the tower freely albeit with a little resistance.
There are two mech connections on the tower, the cam throttle and the timing advance rod that goes to the trigger plate. If the tower is frozen, disconnect one mech connection at a time while checking the tower for free movement. I'll start with the timing advance rod to the trigger plate, since this is most likely where it is frozen.
