jerryjerry05
- May 7, 2008
- 17,927
New marine battery???
Deep cycle???
Don't use a deep cycle.
They will work but your charging system isn't designed to charge them.
Can cause problems after a while.
Spinning starter: battery hooked up backwards?? (been done a lot)(my very first boat )
The Bendix on the top of the starter might need grease?
Lift it up and clean the screw threads with a wire brush.
Then lightly grease the threads.
Too much grease/oil can cause the rubber in the Bendix to fail.
I might have a rectifier?? let me look.
Send me a pm with your address.
Now that it's running? clean the carbs, clean the recirculation system.
Then a can of starting fluid, while running, spray around the intake side of the motor.
If the spray makes any difference then it 's sucking air and needs to be resealed.
Deep cycle???
