Welcome Guest - Sign Up today
No announcement yet.
New steering for an old boat
  • New steering for an old boat
    I'm wondering how feasible it is to put a cable steering system on a 1962 Johnson Super seahorse 75 hp. Right now it has a cable and drum system.
    How difficult is it to mount a teleflex steering system to an outboard that had a cable drum system. It will be going on a 1961 super seahorse 75 hp.
    • #3
      Does your engine presently have a cable tilt tube system? If so, there shouldn't be any problems swapping over. If not, you will need to buy an adapter for the tilt tube setup to work. Check Ezy-Glide and see what they offer for some ideas.
      Tom Boy Boat Project https://forums.iboats.com/forum/boat...s-what-trailer
      Rebuilt trailer project https://forums.iboats.com/forum/gener...r-back-to-life
      '76 40 HP Johnson rebuild https://forums.iboats.com/forum/engin...mplete-rebuild
      Minn Kota 599 Project https://forums.iboats.com/forum/boat-...ta-599-project
      • #4
        My outboard has a solid tilt rod. Any idea if it is possible to change it to a hollow tilt tube? Looking to add a modern steering mechanism
        • #5
          my question is why do you want to change? the drum steering has worked for almost 60 years. there is about $30 worth of parts to rebuild the entire system.
          Cheesehead boating the Gulf Coast of FLA 27.51° N, 82.53° W
          1988 Cruisers Rogue 2420 -VP 290 DP now powered by custom 468 - https://forums.iboats.com/forum/owner...988-rogue-2420
          Past Boats
          1970 Wooster Hellion - Merc 9.8
          2002 SeaRay 190BR - 5.0 - A1G2 - "Cheeseheads in Paradise"
          1984 Avanti 170DLI -3.0 stringer- "Ship Happens"
          What’s behind you doesn’t matter.Enzo Ferrari
          • #6
            I have spent two years and countless hours restoring this boat. Gelcoat removal, transom, floor, etc. Just got it back from paint. Looks like glass. It would break my heart to drill holes through the side of the hull to mount the hardware needed to replace the drum cable. Strictly aesthetic.
            • #7
              Normally, you would have wood covered in glass mounting pads on the interior for mounting hardware. You should not have to drill through the hall itself.
              If ya can't fix it with a hammer,ya got yourself an electrical problem.
              • #8
                Here is what you need to do a change over to standard cable steering at the engine side. That is the exact same setup I am using since I don't have a hollow tilt tube either. JMHO
                • #9
                  Unfortunately the iboats search function isnt working, however using google.
                  https://www.iboats.com/shop/seastar-...hoCZlcQAvD_BwE
                  Past Boats
                  • #10
                    Thanks for the input. I think I will go with the original drum system. I hadn't thought about glassing in some blocks for mounting. Great idea. Now part two. Any idea where I can find a replacement drum for the steering. My original is chipped. I found a couple online but they were in Australia I would prefer to keep the money in the US if possible. Thanks for any input you may have.
                    • #11
                      I have a drum, actually most all the parts. If the drum fits/and is the same size, only pay for shipping.
                      • #12
                        Thank you so much for the offer. Very kind of you. I just noticed it is aluminum and I have the broken chip. Neighbor is a welder said he could fix it. I initially thought it was cast. I really appreciate the offer but I should be ok. I'll keep you in mind if it doesn't work out. Great community here at iboats
