WillPhill3
- Apr 10, 2014
- 4
Im putting a used trim pump in my boat and i believe the solenoid that came with it is either bad or its the wrong one for this pump. I can get the pump to run one direction if i wire it through the solenoid and when i hardwired it i got it to run both directions. I pulled the solenoid off and I noticed its made by motorcraft (ford) and looks identical to the starter solenoid on the engine (ford 351w). Will another ford starter solenoid work? Is there any difference between a starter solenoid and a trim pump solenoid? Thanks
