Have a 2009 SD2400. Owner's Manual has absolutely NOTHING about wiring and provides no diagrams. Have 2 batteries hooked to a 4-way GUEST switch. Can somone please explain how the 2 batteries charge via the switch? Also, I see the 2 battery negatives connected to switch postions 1 & 2 respectively and a jumper from battery 1 to 2 for the posative connection and two other connections of wires below the GUEST switch. Question is what are those wires for? Thanks for any input you can provide.
