Welcome Guest - Sign Up today
No announcement yet.
Question about changing an hour meter
  • Question about changing an hour meter
    Greetings,
    I have a 1987 Cruiser Avante Vee that I restored afew years ago. As part of the restoration, I installed new gauges, one of which was a Faria tachometer with an hour meter. Recently, the tachometer started malfunctioning. The gauge was sticking, a problem that some have reported in the forums. I sent the gauge to Faria and they replaced the gauge with a new one, for a service charge of course. Based on the gauge being new, it does not reflect the hours that are on the motor. My question is would anyone suggest adding hours to the gauge to reflect the actual motor hours? If so, what's the best way to do this? The gauge seems to require the signal from the coil, it does not count hours when battery voltage is supplied. I read that the signal is a square wave which would require a square wave signal generator. Any insight you all can give me would be appreciated.
    Thanks
    Re: Question about changing an hour meter
    Square wave . . . I don't think so . . .
    If you could just leave the ignition on, but not start the engine . . . BUT . . . that is not so good for the ignition system. See if you can apply 12 volts to the hour meter feed on the tach and if that causes the 'clock' to run. If so, you can just let it run up to the amount of hours, etc.
    Best regards, Ted . . . . Cape Cod, MA
    Current Boats: Formula 330 Sun Sport, O'Day Mariner Sail #3224, Sunfish
    Past Boats: Catalina 22 Sail #10531, Formula 242 Sun Sport
    Twin Mercruiser 7.4 LX MPI (0F802036, 039), Bravo 3's (0F806198, 199), Mercury 7.5 HP (1969), Johnson 4.5 HP (1980)
    My Boating Web Pages: http://www.tpenfield.com
    • #3
      You have to hook up both a positive and negative wire to the hour meter for it to work. The gray wire coming from the coil is the signal for the tach for RPM
      Don S.
      Please, no PM's (Private Messages) regarding boat/engine problems.
      That is what the forums are for.
      Only forum/moderator issues will be answered in PM's.
      • #4
        Mine crapped out when I had 1250 hours on it. My new one started at 0. In my log book when i log in hours for service, etc., I log in 1250 + whatever the meter shows.
        2019 SeaRay SPX 190 OB & Mercury 150 4-Stroke & Merc 5.0 Kicker
        2017 Boston Whaler 150 Montauk & Mercury 60 ELPT Command Thrust & Merc 3.5 Kicker
        2015 Yamaha FX Cruiser HO
        1964 Sea Nymph 14R & 1970 Evinrude Sportwin 9.5
        1960 Mulray 100 Dinghy, equipped with Beaver Oars
        1952 Lyman 15' Mid Steer & Evinrude Big Twin 25
        69 Outboards: 1919-2019, representing 11 manufacturers
        Member ACBS, LBOA, AOMCI
        • #5
          From the Faria website -
          "To ensure accuracy, the Pilot 1 Speedometer and all Faria Tach-Hourmeter Combination Instruments utilize Engine Running Only hourmeters. This instrument does not read engine hours until a certain voltage has been achieved during engine use."
          A little ambiguous to say the least. Sounds like it need 14 volts so it thinks the system is producing power and charging.
          How many volts is the tach pulse?
          • #6
            I don't know how many volts the tach pulse is. Let clarify my experiment if it was not clear. I hooked a 12 volt battery to the BAT and GND terminals of the tachometer. This caused the LCD display to illuminate. Since the display measures tenths of an hour, I expected the time to change after 6 minutes but it didn't. This is why I was asking if it required some additional voltage like a tach pulse. I also read the blurb about engine running only hours. I suspect you may be on to something suggesting 14 volts. I am going to try this to see if that works.
            Thanks.
