BL Trophy - 1983 Volvo 4cyl AQ125A w/ Penta 270
I'm looking for advice on re-wiring the panel switch back to the Tilt. The previous owner disconnected the main panel tilt switch and installed a stern switch directly. While this is a convenient placement for a tilt switch (trailoring etc), I'd prefer having both switches operational in parallel. Normally this would be easy enough, but I noticed that there are two different types of switches involved.
The tilt has the standard two wires:
The stern switch is currently wired as follows, directly to the above connections:
The stern switch appears to be a three position DPDT (momentary-on/hold-on style). As you can see the switch is setup to output +/- or -/+ from the center pair, based on the switch being pressed either up or down.
The panel switch also appears to be a three position momentary-on style, but has only 3 connectors on the back, controlling the + only:
Orange is fed from fusebox, and brown/blue make their way to the stern area (the third yellow/green is not connected anywhere):
Here's where things stand:
My problem stems from there not being a negative pole to hook from the panel switch. Obviously just hooking up "g" and "h" to "a" and "b" won't work as there's no "-" when either of those is hot (+).
Any help is greatly appreciated! Thanks.
