Re: what kind of bolts to mount trolling motor on bass boat bow
the isolator bolts are ok, but as you know they will eventually work themselves out. That hardware takes a lot of punishment on the bow. I used a piece of plywood & aluminum bar stock as backerplate. Get the biggest diameter hardward that will fit through the holes on the bracket. Yes, get stainless. and lockwashers.
oh yeah, and the rubber feet from the old isolator bolts. you really do need some rubber in there but it has to be the hardest rubber you can find.
take care not to block off that socket for the bow light riser.......
hey hornpipe, tell your family you want a "dremel" tool for father's day -- rusty bolts, no problem!
