I have 92 Skeeter 175 SF with a fuel gauge problem. The gauge always shows empty. I followed instructions to test the gauge that I found here. The gauge appeared to test fine. Checked the sending unit and it moved the gauge needle when I grounded the sending wire. So I guess my sending unit is bad. Though the voltage in the signal wire was only like 7 volts with a full tank of gas. Hope my conclusion is correct.
Will any generic sending unit work or do I need a specific one? I took some pictures of the tank information and pics of the sending unit... that might be rather hard to get to. You'll see in the following pictures.
Fuel Tank information. Seems like a large tank for a bass boat to me. I guess that is good since my gas gauge isn't working.
Here's the access to the fuel gauge sending unit. Might be hard to change it. Though, looks like someone might have changed it before.
And here's a pic of the top of the sending unit:
Any suggestions are welcome as far as what I need to get. Think I can get the old one out and the new one in without too much trouble? I might have to wait until winter to make sure I have plenty of time in case something goes wrong.
