Re: Trim tabs w/o switch or wiring
You can use one switch to do it all if you pick up a couple of inexpensive relays, they just need to be set up to reverse current depending on which way the switch is pressed.
NOTE: This diagram was drawn for someone else so please ignore the wire colors as yours may be totally different.
The terminals of each relay will be connected as shown above to create a current reversing circuit..
1) Terminal #87 on each relay connected to fused +12v.
2) Terminal #87a on each relay connected to Ground
3) Terminal #30 on the left should be connected to the suspected UP wire of the trim tabs, while #30 on the right relay should be connected to the DOWN wire.
4) Terminals #85 & #86 on the relay energize the coil inside the relay One side should be connected to the same fused +12v as #87 was and the other should be connected to A Momentary SPDT Switch (A switch that is off in the center position and spring loaded so that it only engages while you press it)
The center position of the switch should be connected to ground.
How does this work??
1) When the switch is in the center position the relays are considered "at rest" meaning their coil's are not energized and internally terminal #87a & #30 are connected, thus both wires of the trim motor are grounded.
2) Lets say we press Up on the switch... The grey wire connected to terminal #86 on the left relay becomes grounded, since #85 always has +12v on it the coil in the relay energizes and closes the connection between terminals #87 & #30.. (The connection between #30 and #87a is no longer connected!!!)
This sends +12v down the purple wire connected to #30 on the left relay and a ground down the green wire connected to #30 on the right relay (since it is still at rest), resulting in the trim tabs going up..
3) If we press down on the switch the left relay stays at rest and the situation is reversed sending +12v to the green wire and ground to the purple.
